Go to main content
SPARC T5-4 Server Service Manual
Exit Print View
Updated: February 2019
Install the Rear I/O Module
  1. Take the necessary ESD precautions.
    See Prevent ESD Damage.
  2. With the levers in the extended position, insert the rear I/O module into the slot at the rear of the server.
    image:Graphic showing how to remove the rear I/O module from the server.
  3. Close the extraction levers until they click into place to fully seat the rear I/O module into the server.
    image:Graphic showing how to latch the rear I/O module in place.
  4. Connect the cables to the appropriate ports on the rear I/O module.
  5. Connect the power cords.
    See Connect Power Cords.
  6. Power on the server.
    See Returning the Server to Operation.
  7. Verify the rear I/O installation.
    See Verify the Rear I/O Module.
Related Information
