Go to main content
SPARC T5-4 Server Service Manual
Exit Print View
Updated: February 2019
Determine Which Hard Drive Is Faulty
The following LEDs are lit when a hard drive fault is detected:
  • System Service Required LEDs on the front panel and rear I/O module
  • Service Required LED on the faulty drive
  1. Determine if the System Service Required LEDs are lit on the front panel or the rear I/O module.
    See Interpreting LEDs.
  2. From the front of the server, check the drive LEDs to identify which drive needs to be replaced.
    See Hard Drive LEDs. The amber Service Required LED is lit on the drive that needs to be replaced.
  3. Remove the faulty drive.
    See Remove a Hard Drive.
Related Information
