hal-device [-h] [--a udi | --r udi]
The Hardware Abstraction Layer (HAL) provides a view of the various hardware attached to a system. The hal-device command enables you to manage devices that conform to the HAL standard. Specifically, hal-device lets you add or remove a device to or from the HAL global device list. Device properties are read from stdin in lshal(1M) syntax.
The following options are supported:
Add device specified by Universal Device Identifier udi to HAL's global device list.
Display usage information.
Remove device specified by Universal Device Identifier udi from HAL's global device list.
