Diagnostic Tools
The selection of diagnostic tools available for your server range in complexity
from a comprehensive validation test suite (Oracle VTS) to a chronological event log
(Oracle ILOM System Log). The selection of diagnostic tools also include standalone
software packages, firmware-based tests, and hardware-based LED indicators.
The following table summarizes the diagnostic tools that you can use when
troubleshooting or monitoring your server.
Oracle ILOM
SP firmware
Monitors environmental condition and component functionality
sensors, generates alerts, performs fault isolation, and
provides remote access.
Available in either standby power mode or full power mode. It
is not OS dependent.
Designed for remote and local access.
Preboot Menu
SP firmware
Enables you to restore some of Oracle ILOM defaults (including
firmware) when Oracle ILOM is not accessible.
Local, but remote serial access is possible if the SP serial
port is connected to a network-accessible terminal
server.
Hardware-based LED indicators
Hardware and SP firmware
Indicates status of overall system and particular components.
Available when system power is available.
Local, but sensor and indicators are accessible from Oracle
ILOM web interface or command-line interface (CLI).
Power-on Self-Test (POST)
Host firmware
Tests core components of system: CPUs, memory, and motherboard
I/O bridge integrated circuits.
Runs on startup. Available when the operating system is not
running.
Local, but can be accessed through Oracle ILOM Remote
Console.
U-Boot
SP firmware
Initializes and test aspects of the service processor (SP)
prior to booting the Oracle ILOM SP and operating system. Tests
SP memory, SP, network devices and I/O devices.
server.
Solaris commands
Operating system software
Displays various kinds of system information.
Requires operating system.
Local, and over network.
Oracle VTS
Diagnostic tool standalone software
Exercises and stresses the system, running tests in parallel.
Requires operating system. Install Oracle VTS software
separately.
View and control over network.
