Skip Navigation Links
Exit Print View
man pages section 7: Device and Network Interfaces     Oracle Solaris 11 Information Library
search filter icon
search icon
Document Information
Preface
Introduction
1394(7D)
aac(7D)
adpu320(7D)
afe(7D)
agpgart_io(7I)
AH(7P)
ahci(7D)
allkmem(7D)
amd8111s(7D)
arcmsr(7D)
arn(7D)
ARP(7P)
arp(7P)
ast(7D)
asy(7D)
ata(7D)
atge(7D)
ath(7D)
atu(7D)
audio1575(7D)
audio(7D)
audio(7I)
audio810(7D)
audiocmi(7D)
audiocs(7D)
audioemu10k(7D)
audioens(7D)
audiohd(7D)
audioixp(7D)
audiols(7D)
audiop16x(7D)
audiopci(7D)
audiosolo(7D)
audiots(7D)
audiovia823x(7D)
av1394(7D)
bbc_beep(7D)
bcm_sata(7D)
bfe(7D)
bge(7D)
blkdev(7D)
bmc(7D)
bnx(7D)
bnxe(7D)
bpf(7D)
bscbus(7D)
bscv(7D)
bufmod(7M)
cdio(7I)
chxge(7D)
cmdk(7D)
connld(7M)
console(7D)
cpqary3(7D)
cpr(7)
cpuid(7D)
ctfs(7FS)
ctsmc(7D)
cvc(7D)
cvcredir(7D)
cxge(7D)
dad(7D)
daplt(7D)
dca(7D)
dcam1394(7D)
dcfs(7FS)
dev(7FS)
devchassis(7FS)
devfs(7FS)
devinfo(7D)
dkio(7I)
dlcosmk(7ipp)
dlpi(7P)
dm2s(7D)
dmfe(7D)
dnet(7D)
dr(7d)
drmach(7d)
dscpmk(7ipp)
dsp(7I)
dtrace(7D)
e1000(7D)
e1000g(7D)
ecpp(7D)
efb(7D)
ehci(7D)
eibnx(7D)
eiob(7D)
elxl(7D)
emlxs(7D)
eri(7D)
ESP(7P)
fas(7D)
fasttrap(7D)
fbio(7I)
fbt(7D)
fcip(7D)
fcoe(7D)
fcoei(7D)
fcoet(7D)
fcp(7D)
fctl(7D)
fipe(7D)
firewire(7D)
flowacct(7ipp)
fp(7d)
FSS(7)
gld(7D)
glm(7D)
gpio_87317(7D)
grbeep(7d)
hci1394(7D)
hdio(7I)
heci(7D)
hermon(7D)
hid(7D)
hme(7D)
hsfs(7FS)
hubd(7D)
hwa1480_fw(7D)
hwahc(7D)
hwarc(7D)
hxge(7D)
i2bsc(7D)
i915(7d)
ib(7D)
ibcm(7D)
ibdm(7D)
ibdma(7D)
ibmf(7)
ibp(7D)
ibtl(7D)
icmp6(7P)
ICMP(7P)
icmp(7P)
idn(7d)
iec61883(7I)
ieee1394(7D)
if(7P)
ifp(7D)
if_tcp(7P)
igb(7D)
igbvf(7D)
ii(7D)
imraid_sas(7D)
inet6(7P)
inet(7P)
ip6(7P)
IP(7P)
ip(7P)
ipgpc(7ipp)
ipmi(7D)
ipnat(7I)
ipnet(7D)
ipqos(7ipp)
iprb(7D)
ipsec(7P)
ipsecah(7P)
ipsecesp(7P)
ipw(7D)
iscsi(7D)
isdnio(7I)
iser(7D)
isp(7D)
iwh(7D)
iwi(7D)
iwk(7D)
iwp(7D)
ixgb(7d)
ixgbe(7D)
ixgbevf(7D)
kb(7M)
kdmouse(7D)
kmdb(7d)
kmem(7D)
kstat(7D)
ksyms(7D)
ldterm(7M)
llc1(7D)
llc2(7D)
lo0(7D)
lockstat(7D)
lofi(7D)
lofs(7FS)
log(7D)
marvell88sx(7D)
mc-opl(7D)
mcxe(7D)
md(7D)
mediator(7D)
mega_sas(7D)
mem(7D)
mhd(7i)
mixer(7I)
mpt(7D)
mpt_sas(7D)
mr_sas(7D)
msglog(7D)
mt(7D)
mtio(7I)
mwl(7D)
mxfe(7D)
myri10ge(7D)
n2cp(7d)
n2rng(7d)
nca(7d)
ncp(7D)
ngdr(7d)
ngdrmach(7d)
nge(7D)
npe(7D)
ntwdt(7D)
ntxn(7D)
null(7D)
nulldriver(7D)
nv_sata(7D)
nxge(7D)
objfs(7FS)
oce(7D)
ohci(7D)
openprom(7D)
oplkmdrv(7D)
oplmsu(7D)
oplpanel(7D)
packet(7P)
pcan(7D)
pcata(7D)
pcfs(7FS)
pcic(7D)
pcicmu(7D)
pcie_pci(7D)
pcipsy(7D)
pcisch(7D)
pckt(7M)
pcmcia(7D)
pcn(7D)
pcser(7D)
pcwl(7D)
pf_key(7P)
pfmod(7M)
PF_PACKET(7P)
physmem(7D)
pipemod(7M)
pm(7D)
poll(7d)
prnio(7I)
profile(7D)
ptem(7M)
ptm(7D)
pts(7D)
pty(7D)
qfe(7d)
qlc(7D)
qlcnic(7D)
qlge(7D)
quotactl(7I)
radeon(7d)
ral(7D)
ramdisk(7D)
random(7D)
RARP(7P)
rarp(7P)
rge(7D)
route(7P)
routing(7P)
rtls(7D)
rtw(7D)
rum(7D)
rwd(7D)
rwn(7D)
sad(7D)
sata(7D)
scfd(7D)
schpc(7D)
scsa1394(7D)
scsa2usb(7D)
scsi_vhci(7D)
SCTP(7P)
sctp(7P)
scu(7D)
sd(7D)
sda(7D)
SDC(7)
sdcard(7D)
sdhost(7D)
sdp(7D)
sdt(7D)
se(7D)
se_hdlc(7D)
ses(7D)
sesio(7I)
sf(7D)
sfe(7D)
sgen(7D)
sharefs(7FS)
si3124(7D)
sip(7P)
slp(7P)
smbfs(7FS)
smbios(7D)
smbus(7D)
smp(7D)
snca(7d)
socal(7D)
sockio(7I)
sol_ofs(7D)
sol_ucma(7D)
sol_umad(7D)
sol_uverbs(7D)
sppptun(7M)
srpt(7D)
ssd(7D)
st(7D)
streamio(7I)
su(7D)
sv(7D)
sxge(7D)
sysmsg(7D)
systrace(7D)
tavor(7D)
TCP(7P)
tcp(7P)
termio(7I)
termiox(7I)
ticlts(7D)
ticots(7D)
ticotsord(7D)
timod(7M)
tirdwr(7M)
tmpfs(7FS)
todopl(7D)
tokenmt(7ipp)
tsalarm(7D)
tswtclmt(7ipp)
ttcompat(7M)
tty(7D)
ttymux(7D)
tzmon(7d)
uata(7D)
uath(7D)
udfs(7FS)
UDP(7P)
udp(7P)
ufs(7FS)
ugen(7D)
uhci(7D)
ural(7D)
urandom(7D)
urtw(7D)
usb(7D)
usba(7D)
usb_ac(7D)
usb_ah(7M)
usb_as(7D)
usbecm(7D)
usbftdi(7D)
usb_ia(7D)
usbkbm(7M)
usb_mid(7D)
usbms(7M)
usbprn(7D)
usbsacm(7D)
usbser_edge(7D)
usbsksp(7D)
usbsprl(7D)
usbvc(7D)
usbwcm(7M)
uscsi(7I)
usmp(7I)
uvfs(7FS)
uwb(7D)
uwba(7D)
virtualkm(7D)
visual_io(7I)
vni(7d)
vr(7D)
vt(7I)
vuid2ps2(7M)
vuid3ps2(7M)
vuidm3p(7M)
vuidm4p(7M)
vuidm5p(7M)
vuidmice(7M)
vxge(7D)
wpi(7D)
wscons(7D)
wusb_ca(7D)
wusb_df(7D)
xge(7D)
yge(7D)
zcons(7D)
zero(7D)
zfs(7FS)
zs(7D)
zsh(7D)
zyd(7D)
audio
- generic audio device interface
Synopsis
#include <sys/audio.h>
OVERVIEW
An audio device is used to play and/or record a stream of audio data. Since a specific audio device may not support all functionality described below, refer to the device-specific manual pages for a complete description of each hardware device. An application can use the AUDIO_GETDEV ioctl(2) to determine the current audio hardware associated with /dev/audio.
The audio framework provides a software mixing engine (audio mixer) for all audio devices, allowing more than one process to play or record audio at the same time.
Backward Compatibility
It is no longer possible to disable the mixing function. Applications must not assume that they have exclusive access to the audio device.
Multi-Stream Codecs
The audio mixer supports multi-stream Codecs. These devices have DSP engines that provide sample rate conversion, hardware mixing, and other features. The use of such hardware features is opaque to applications.
AUDIO FORMATS
Digital audio data represents a quantized approximation of an analog audio signal waveform. In the simplest case, these quantized numbers represent the amplitude of the input waveform at particular sampling intervals. To achieve the best approximation of an input signal, the highest possible sampling frequency and precision should be used. However, increased accuracy comes at a cost of increased data storage requirements. For instance, one minute of monaural audio recorded in µ-Law format (pronounced mew-law) at 8 KHz requires nearly 0.5 megabytes of storage, while the standard Compact Disc audio format (stereo 16-bit linear PCM data sampled at 44.1 KHz) requires approximately 10 megabytes per minute.
Audio data may be represented in several different formats. An audio device's current audio data format can be determined by using the AUDIO_GETINFO ioctl(2) described below.
An audio data format is characterized in the audio driver by four parameters: Sample Rate, Encoding, Precision, and Channels. Refer to the device-specific manual pages for a list of the audio formats that each device supports. In addition to the formats that the audio device supports directly, other formats provide higher data compression. Applications may convert audio data to and from these formats when playing or recording.
Sample Rate
Sample rate is a number that represents the sampling frequency (in samples per second) of the audio data.
The audio mixer always configures the hardware for the highest possible sample rate for both play and record. This ensures that none of the audio streams require compute-intensive low pass filtering. The result is that high sample rate audio streams are not degraded by filter ing.
Sample rate conversion can be a compute-intensive operation, depending on the number of channels and a device's sample rate. For example, an 8KHz signal can be easily converted to 48KHz, requiring a low cost up sampling by 6. However, converting from 44.1KHz to 48KHz is compute intensive because it must be up sampled by 160 and then down sampled by 147. This is only done using integer multipliers.
Applications can greatly reduce the impact of sample rate conversion by carefully picking the sample rate. Applications should always use the highest sample rate the device supports. An application can also do its own sample rate conversion (to take advantage of floating point and accelerated instruction or use small integers for up and down sampling.
All modern audio devices run at 48 kHz or a multiple thereof, hence just using 48 kHz may be a reasonable compromise if the application is not prepared to select higher sample rates.
Encodings
An encoding parameter specifies the audio data representation. µ-Law encoding corresponds to CCITT G.711, and is the standard for voice data used by telephone companies in the United States, Canada, and Japan. A-Law encoding is also part of CCITT G.711 and is the standard encoding for telephony elsewhere in the world. A-Law and µ-Law audio data are sampled at a rate of 8000 samples per second with 12-bit precision, with the data compressed to 8-bit samples. The resulting audio data quality is equivalent to that of standard analog telephone service.
Linear Pulse Code Modulation (PCM) is an uncompressed, signed audio format in which sample values are directly proportional to audio signal voltages. Each sample is a 2's complement number that represents a positive or negative amplitude.
Precision
Precision indicates the number of bits used to store each audio sample. For instance, u-Law and A-Law data are stored with 8-bit precision. PCM data may be stored at various precisions, though 16-bit is the most common.
Channels
Multiple channels of audio may be interleaved at sample boundaries. A sample frame consists of a single sample from each active channel. For example, a sample frame of stereo 16-bit PCM data consists of two 16-bit samples, corresponding to the left and right channel data.
The audio mixer sets the hardware to the maximum number of channels supported. If a mono signal is played or recorded, it is mixed on the first two (usually the left and right) channels only. Silence is mixed on the remaining channels
Supported Formats
The audio mixer supports the following audio formats:
Encoding           Precision   Channels
Signed Linear PCM  32-bit      Mono or Stereo
Signed Linear PCM  16-bit      Mono or Stereo
Signed Linear PCM   8-bit      Mono or Stereo
u-Law               8-bit      Mono or Stereo
A-Law               8-bit      Mono or Stereo
The audio mixer converts all audio streams to 24-bit Linear PCM before mixing. After mixing, conversion is made to the best possible Codec format. The conversion process is not compute intensive and audio applications can choose the encoding format that best meets their needs.
Note that the mixer discards the low order 8 bits of 32-bit Signed Linear PCM in order to perform mixing. (This is done to allow for possible overflows to fit into 32-bits when mixing multiple streams together.) Hence, the maximum effective precision is 24-bits.
Description
The device /dev/audio is a device driver that dispatches audio requests to the appropriate underlying audio hardware. The audio driver is implemented as a STREAMS driver. In order to record audio input, applications open(2) the /dev/audio device and read data from it using the read(2) system call. Similarly, sound data is queued to the audio output port by using the write(2) system call. Device configuration is performed using the ioctl(2) interface.
Because some systems may contain more than one audio device, application writers are encouraged to query the AUDIODEV environment variable. If this variable is present in the environment, its value should identify the path name of the default audio device.
Opening the Audio Device
The audio device is not treated as an exclusive resource. Each process may open the audio device once.
Each open() completes as long as there are channels available to be allocated. If no channels are available to be allocated:
Upon the initial open() of the audio channel, the audio mixer sets the data format of the audio channel to the default state of 8-bit, 8Khz, mono u-Law data. If the audio device does not support this configuration, it informs the audio mixer of the initial configuration. Audio applications should explicitly set the encoding characteristics to match the audio data requirements, and not depend on the default configuration.
Recording Audio Data
The read() system call copies data from the system's buffers to the application. Ordinarily, read() blocks until the user buffer is filled. The I_NREAD ioctl (see streamio(7I)) may be used to determine the amount of data that may be read without blocking. The device may alternatively be set to a non-blocking mode, in which case read() completes immediately, but may return fewer bytes than requested. Refer to the read(2) manual page for a complete description of this behavior.
When the audio device is opened with read access, the device driver immediately starts buffering audio input data. Since this consumes system resources, processes that do not record audio data should open the device write-only (O_WRONLY).
The transfer of input data to STREAMS buffers may be paused (or resumed) by using the AUDIO_SETINFO ioctl to set (or clear) the record.pause flag in the audio information structure (see below). All unread input data in the STREAMS queue may be discarded by using the I_FLUSH STREAMS ioctl. See streamio(7I). When changing record parameters, the input stream should be paused and flushed before the change, and resumed afterward. Otherwise, subsequent reads may return samples in the old format followed by samples in the new format. This is particularly important when new parameters result in a changed sample size.
Input data can accumulate in STREAMS buffers very quickly. At a minimum, it will accumulate at 8000 bytes per second for 8-bit, 8 KHz, mono, u-Law data. If the device is configured for 16-bit linear or higher sample rates, it will accumulate even faster. If the application that consumes the data cannot keep up with this data rate, the STREAMS queue may become full. When this occurs, the record.error flag is set in the audio information structure and input sampling ceases until there is room in the input queue for additional data. In such cases, the input data stream contains a discontinuity. For this reason, audio recording applications should open the audio device when they are prepared to begin reading data, rather than at the start of extensive initialization.
Playing Audio Data
The write() system call copies data from an application's buffer to the STREAMS output queue. Ordinarily, write() blocks until the entire user buffer is transferred. The device may alternatively be set to a non-blocking mode, in which case write() completes immediately, but may have transferred fewer bytes than requested. See write(2).
Although write() returns when the data is successfully queued, the actual completion of audio output may take considerably longer. The AUDIO_DRAIN ioctl may be issued to allow an application to block until all of the queued output data has been played. Alternatively, a process may request asynchronous notification of output completion by writing a zero-length buffer (end-of-file record) to the output stream. When such a buffer has been processed, the play.eof flag in the audio information structure is incremented.
The final close(2) of the file descriptor hangs until all of the audio output has drained. If a signal interrupts the close(), or if the process exits without closing the device, any remaining data queued for audio output is flushed and the device is closed immediately.
The consumption of output data may be paused (or resumed) by using the AUDIO_SETINFO ioctl to set (or clear) the play.pause flag in the audio information structure. Queued output data may be discarded by using the I_FLUSH STREAMS ioctl. (See streamio(7I)).
Output data is played from the STREAMS buffers at a default rate of at least 8000 bytes per second for µ-Law, A-Law or 8–bit PCM data (faster for 16-bit linear data or higher sampling rates). If the output queue becomes empty, the play.error flag is set in the audio information structure and output is stopped until additional data is written. If an application attempts to write a number of bytes that is not a multiple of the current sample frame size, an error is generated and the bad data is thrown away. Additional writes are allowed.
Asynchronous I/O
The I_SETSIG STREAMS ioctl enables asynchronous notification, through the SIGPOLL signal, of input and output ready condition changes. The O_NONBLOCK flag may be set using the F_SETFL fcntl(2) to enable non-blocking read() and write() requests. This is normally sufficient for applications to maintain an audio stream in the background.
Audio Control Pseudo-Device
It is sometimes convenient to have an application, such as a volume control panel, modify certain characteristics of the audio device while it is being used by an unrelated process.
The /dev/audioctl pseudo-device is provided for this purpose. Any number of processes may open /dev/audioctl simultaneously. However, read() and write() system calls are ignored by /dev/audioctl. The AUDIO_GETINFO and AUDIO_SETINFO ioctl commands may be issued to /dev/audioctl to determine the status or alter the behavior of /dev/audio. Note: In general, the audio control device name is constructed by appending the letters "ctl" to the path name of the audio device.
Audio Status Change Notification
Applications that open the audio control pseudo-device may request asynchronous notification of changes in the state of the audio device by setting the S_MSG flag in an I_SETSIG STREAMS ioctl. Such processes receive a SIGPOLL signal when any of the following events occur:
ioctls
Audio Information Structure
The state of the audio device may be polled or modified using the AUDIO_GETINFO and AUDIO_SETINFO ioctl commands. These commands operate on the audio_info structure as defined, in <sys/audio.h>, as follows:
* This structure contains state information for audio device
* IO streams
struct audio_prinfo {
  * The following values describe the
  * audio data encoding
 uint_t sample_rate; /* samples per second */
 uint_t channels;  /* number of interleaved channels */
 uint_t precision; /* number of bits per sample */
 uint_t encoding;  /* data encoding method */
  * The following values control audio device
  * configuration
 uint_t gain; /* volume level */
 uint_t port; /* selected I/O port */
 uint_t buffer_size; /* I/O buffer size */
  * The following values describe the current device
  * state
 uint_t samples; /* number of samples converted */
 uint_t eof;  /* End Of File counter (play only) */
 uchar_t pause;  /* non-zero if paused, zero to resume */
 uchar_t error; /* non-zero if overflow/underflow */
 uchar_t waiting; /* non-zero if a process wants access */
 uchar_t balance; /* stereo channel balance */
   * The following values are read-only device state
   * information
 uchar_t open;/* non-zero if open access granted */
 uchar_t active; /* non-zero if I/O active */
 uint_t avail_ports; /* available I/O ports */
 uint_t mod_ports; /* modifiable I/O ports */
typedef struct audio_prinfo audio_prinfo_t;
  * This structure is used in AUDIO_GETINFO and AUDIO_SETINFO ioctl
  * commands
struct audio_info {
 audio_prinfo_t record;/* input status info */
 audio_prinfo_t play;/* output status info */
 uint_t monitor_gain; /* input to output mix */
 uchar_toutput_muted; /* non-zero if output muted */
 uint_t hw_features; /* supported H/W features */
 uint_t sw_features;/* supported S/W features */
 uint_t sw_features_enabled;
                /* supported S/W features enabled */
typedef struct audio_info audio_info_t;
/* Audio encoding types */
#define AUDIO_ENCODING_ULAW (1) /* u-Law encoding */
#define AUDIO_ENCODING_ALAW (2) /* A-Law encoding */
#define AUDIO_ENCODING_LINEAR (3) /* Signed Linear PCM encoding */
* These ranges apply to record, play, and
* monitor gain values
#define AUDIO_MIN_GAIN (0)/* minimum gain value */
#define AUDIO_MAX_GAIN (255) /* maximum gain value */
* These values apply to the balance field to adjust channel
* gain values
#define AUDIO_LEFT_BALANCE(0) /* left channel only */
#define AUDIO_MID_BALANCE (32) /* equal left/right balance */
#define AUDIO_RIGHT_BALANCE (64) /* right channel only */
* Define some convenient audio port names
* (for port, avail_ports and mod_ports)
/* output ports (several might be enabled at once) */
#define AUDIO_SPEAKER (0x01)/* built-in speaker */
#define AUDIO_HEADPHONE (0x02)/* headphone jack */
#define AUDIO_LINE_OUT (0x04)/* line out */
#define AUDIO_SPDIF_OUT (0x08)/* SPDIF port */
#define AUDIO_AUX1_OUT (0x10)/* aux1 out */
#define AUDIO_AUX2_OUT (0x20)/* aux2 out */
/* input ports (usually only one may be
* enabled at a time)
#define AUDIO_MICROPHONE (0x01) /* microphone */
#define AUDIO_LINE_IN (0x02) /* line in */
#define AUDIO_CD(0x04) /* on-board CD inputs */
#define AUDIO_SPDIF_IN (0x08) /* SPDIF port */
#define AUDIO_AUX1_IN (0x10) /* aux1 in */
#define AUDIO_AUX2_IN (0x20) /* aux2 in */
#define AUDIO_CODEC_LOOPB_IN (0x40) /* Codec inter.loopback */
/* These defines are for hardware features */
#define AUDIO_HWFEATURE_DUPLEX (0x00000001u)
/*simult. play & cap. supported */
#define AUDIO_HWFEATURE_MSCODEC (0x00000002u)
/* multi-stream Codec */
/* These defines are for software features *
#define AUDIO_SWFEATURE_MIXER (0x00000001u)
 /* audio mixer audio pers. mod. */
* Parameter for the AUDIO_GETDEV ioctl
* to determine current audio devices
*/#define MAX_AUDIO_DEV_LEN(16)
struct audio_device {
 char name[MAX_AUDIO_DEV_LEN];
 char version[MAX_AUDIO_DEV_LEN];
 char config[MAX_AUDIO_DEV_LEN];
typedef struct audio_device audio_device_t;
The play.gain and record.gain fields specify the output and input volume levels. A value of AUDIO_MAX_GAIN indicates maximum volume. Audio output may also be temporarily muted by setting a non-zero value in the output_muted field. Clearing this field restores audio output to the normal state.
The monitor_gain field is present for compatibility, and is no longer supported. See dsp(7I) for more detail.
Likewise, the play.port, play.ports, play.mod_ports, record.port, record.ports, and record.mod_ports are no longer supported. See dsp(7I) for more detail.
The play.balance and record.balance fields are fixed to AUDIO_MID_BALANCE. Changes to volume levels for different channels can be made using the interfaces in dsp(7I).
The play.pause and record.pause flags may be used to pause and resume the transfer of data between the audio device and the STREAMS buffers. The play.error and record.error flags indicate that data underflow or overflow has occurred. The play.active and record.active flags indicate that data transfer is currently active in the corresponding direction.
The play.open and record.open flags indicate that the device is currently open with the corresponding access permission. The play.waiting and record.waiting flags provide an indication that a process may be waiting to access the device. These flags are set automatically when a process blocks on open(), though they may also be set using the AUDIO_SETINFO ioctl command. They are cleared only when a process relinquishes access by closing the device.
The play.samples and record.samples fields are zeroed at open() and are incremented each time a data sample is copied to or from the associated STREAMS queue. Some audio drivers may be limited to counting buffers of samples, instead of single samples for their samples accounting. For this reason, applications should not assume that the samples fields contain a perfectly accurate count. The play.eof field increments whenever a zero-length output buffer is synchronously processed. Applications may use this field to detect the completion of particular segments of audio output.
The record.buffer_size field controls the amount of input data that is buffered in the device driver during record operations. Applications that have particular requirements for low latency should set the value appropriately. Note however that smaller input buffer sizes may result in higher system overhead. The value of this field is specified in bytes and drivers will constrain it to be a multiple of the current sample frame size. Some drivers may place other requirements on the value of this field. Refer to the audio device-specific manual page for more details. If an application changes the format of the audio device and does not modify the record.buffer_size field, the device driver may use a default value to compensate for the new data rate. Therefore, if an application is going to modify this field, it should modify it during or after the format change itself, not before. When changing the record.buffer_size parameters, the input stream should be paused and flushed before the change, and resumed afterward. Otherwise, subsequent reads may return samples in the old format followed by samples in the new format. This is particularly important when new parameters result in a changed sample size. If you change the record.buffer_size for the first packet, this protocol must be followed or the first buffer will be the default buffer size for the device, followed by packets of the requested change size.
The record.buffer_size field may be modified only on the /dev/audio device by processes that have it opened for reading.
The play.buffer_size field is currently not supported.
The audio data format is indicated by the sample_rate, channels, precision and encoding fields. The values of these fields correspond to the descriptions in the AUDIO FORMATS section of this man page. Refer to the audio device-specific manual pages for a list of supported data format combinations.
The data format fields can be modified only on the /dev/audio device.
If the parameter changes requested by an AUDIO_SETINFO ioctl cannot all be accommodated, ioctl() returns with errno set to EINVAL and no changes are made to the device state.
Streamio IOCTLS
All of the streamio(7I) ioctl commands may be issued for the /dev/audio device. Because the /dev/audioctl device has its own STREAMS queues, most of these commands neither modify nor report the state of /dev/audio if issued for the /dev/audioctl device. The I_SETSIG ioctl may be issued for /dev/audioctl to enable the notification of audio status changes, as described above.
Audio IOCTLS
The audio device additionally supports the following ioctl commands:
AUDIO_DRAIN
The argument is ignored. This command suspends the calling process until the output STREAMS queue is empty and all queued samples have been played, or until a signal is delivered to the calling process. It may not be issued for the /dev/audioctldevice. An implicit AUDIO_DRAIN is performed on the final close() of /dev/audio.
AUDIO_GETDEV
The argument is a pointer to an audio_device_t structure. This command may be issued for either /dev/audio or /dev/audioctl. The returned value in the name field will be a string that will identify the current /dev/audio hardware device, the value in version will be a string indicating the current version of the hardware, and config will be a device-specific string identifying the properties of the audio stream associated with that file descriptor. Refer to the audio device-specific manual pages to determine the actual strings returned by the device driver.
AUDIO_GETINFO
The argument is a pointer to an audio_info_t structure. This command may be issued for either /dev/audio or /dev/audioctl. The current state of the /dev/audio device is returned in the structure.
Values return pertain to a logical view of the device as seen by and private to the process, and do not necessarily reflect the actual hardware device itself.
AUDIO_SETINFO
The argument is a pointer to an audio_info_t structure. This command may be issued for either the /dev/audio or the /dev/audioctl device with some restrictions. This command configures the audio device according to the supplied structure and overwrites the existing structure with the new state of the device. Note: The play.samples, record.samples, play.error, record.error, and play.eof fields are modified to reflect the state of the device when the AUDIO_SETINFO is issued. This allows programs to automatically modify these fields while retrieving the previous value.
As with AUDIO_SETINFO, the settings managed by this ioctl deal with a logical view of the device which is private to the process, and don't necessarily have any impact on the hardware device itself.
Certain fields in the audio information structure, such as the pause flags, are treated as read-only when /dev/audio is not open with the corresponding access permission. Other fields, such as the gain levels and encoding information, may have a restricted set of acceptable values. Applications that attempt to modify such fields should check the returned values to be sure that the corresponding change took effect. The sample_rate, channels, precision, and encoding fields treated as read-only for /dev/audioctl, so that applications can be guaranteed that the existing audio format will stay in place until they relinquish the audio device. AUDIO_SETINFO will return EINVAL when the desired configuration is not possible, or EBUSY when another process has control of the audio device.
All of the logical device state is reset when the corresponding I/O stream of /dev/audio is closed.
The audio_info_t structure may be initialized through the use of the AUDIO_INITINFO macro. This macro sets all fields in the structure to values that are ignored by the AUDIO_SETINFO command. For instance, the following code switches the output port from the built-in speaker to the headphone jack without modifying any other audio parameters:
audio_info_t info;
AUDIO_INITINFO();
info.play.port = AUDIO_HEADPHONE;
err = ioctl(audio_fd, AUDIO_SETINFO, );
This technique eliminates problems associated with using a sequence of AUDIO_GETINFO followed by AUDIO_SETINFO.
Errors
An open() will fail if:
EBUSY
The requested play or record access is busy and either the O_NDELAY or O_NONBLOCK flag was set in the open() request.
EINTR
The requested play or record access is busy and a signal interrupted the open() request.
An ioctl() will fail if:
EINVAL
The parameter changes requested in the AUDIO_SETINFO() ioctl are invalid or are not supported by the device.
Files
The physical audio device names are system dependent and are rarely used by programmers. Programmers should use the following generic device names:
/dev/audio
Symbolic link to the system's primary audio device
/dev/audioctl
Symbolic link to the control device for /dev/audio
/dev/sound/0
First audio device in the system
/dev/sound/0ctl
Audio control device for /dev/sound/0
/usr/share/audio/samples
Audio files
Attributes
See attributes(5) for a description of the following attributes:
ATTRIBUTE TYPE
ATTRIBUTE VALUE
Architecture
SPARC, x86
Availability
system/io/audio
Interface Stability
Obsolete Uncommitted
See Also
close(2), fcntl(2), ioctl(2), open(2), poll(2), read(2), write(2), attributes(5), dsp(7I), streamio(7I)
Bugs
Due to a feature of the STREAMS implementation, programs that are terminated or exit without closing the audio device may hang for a short period while audio output drains. In general, programs that produce audio output should catch the SIGINT signal and flush the output stream before exiting.
