Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Identify All Switches in the Fabric
Identify All HCAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display the Link Status of a Node
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Display the InfiniBand Fabric Partition Configuration
Display the InfiniBand Fabric Configuration
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Exchange Master Fabric Director Status
Partitioning the InfiniBand Fabric
Remove User Partitions for Firmware Downgrade
Determine Partitions and P_Keys
Add or Remove a Port From a Partition
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
Before You Begin
Before you can use the fabric MIBs, you must first create a fabric configuration. You must create identical configurations on all elements of the fabric.
Note - At this time, the fdconfig command is only available to the root user.
# fdconfig start-fabric-config empty #
# fdconfig define-fabric-name name
where name is the identifier of the fabric. For example:
# fdconfig define-fabric-name test Fabric name updated #
# fdconfig define-element -name name -ip IP_address -type type -role role1 [-role role2]
where:
name is the identifier of the element (can be host name).
IP_address is the IP address of an element.
type is the identifer of the type of element:
sw36 – Sun Datacenter InfiniBand Switch 36
sw36gw – Sun Network QDR InfiniBand Gateway Switch
unknown – The element’s type is unknown.
role is the purpose of the element:
gateway – The element acts as a gateway.
spineSwitch – The element acts as a spine switch.
leafSwitch – The element acts as a leaf switch.
unknown – The element’s role is unknown.
For example:
# fdconfig define-element -name primary -ip 123.45.67.89 -type sw36gw -role leafSwitch -role gateway Element added #
# fdconfig list-in-progress-fabric-config Name IP Addr Type Role(s) isMaster Fabricname -------------------------------- ---------------- ------ -------------------- -------- ---------- primary 123.45.67.89 sw36gw gateway yes test #
# fdconfig complete-fabric-config #
# fdconfig start-fabric-config from-current #
Note - There must be only one element hosting the master Fabric Director within the fabric.
# fdconfig set-master name
where name is the identifier assigned to the element to host the master Fabric Director. For example:
# fdconfig set-master primary Element primary updated #
The configuration files and fabric MIBs are created.
