Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Identify All Switches in the Fabric
Identify All HCAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display the Link Status of a Node
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Display the InfiniBand Fabric Partition Configuration
Display the InfiniBand Fabric Configuration
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Exchange Master Fabric Director Status
Partitioning the InfiniBand Fabric
Remove User Partitions for Firmware Downgrade
Determine Partitions and P_Keys
Add or Remove a Port From a Partition
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
You can modify the partition’s configuration or the port(s) membership with the smpartition modify command.
# smpartition start #
# smpartition modify -n partition_name|-pkey p_key[-flag [ipoib, mtu mtu, rate rate, sl sl, scope scope]]|[-port port|ALL|ALL_CAS|ALL_SWITCHES|ALL_ROUTERS|SELF [-m member]
where:
partition_name is the identifier of the InfiniBand partition.
p_key is the partition key (1 – 7fff).
mtu is the value of the MTU.
rate is the throughput of a link (link width + link speed) in Gbps from 2.5, 5, 10, 20, 30 to a maximum of 40.
sl is the service level.
scope is the multicast address scope value (0 – F).
Note - The mtu, rate, sl, and scope parameters are for the multicast group created when ipoib (IP over InfiniBand) is configured for the partition.
port is the GUID of the port, or the special parameter, to modify:
ALL – All of the CAs, switches, and routers in the InfiniBand fabric.
ALL_CAS – All CAs in the InfiniBand fabric.
ALL_SWITCHES – All switches.
ALL_ROUTERS – All routers.
SELF – The Master Subnet Manager.
member is the membership type (full, limited, or both) for the port.
For example, to configure the default partition for limited membership for CAs and no IP over InfiniBand support:
# smpartition modify -pkey 0x7fff -port ALL_CAS -flag -m limited #
# smpartition list modified # Sun DCS IB partition config file # This file is generated, do not edit #! version_number : 13 Default=0x7fff, ipoib : ALL_CAS=full, ALL_SWITCHES=full, SELF=full; SUN_DCS=0x0001, ipoib : ALL_SWITCHES=full; testpartition = 0x0005,defmember=full,ipoib: 0x00212800013e9313, 0x00212800013e93f7; #
# smpartition commit #
