Skip Navigation Links | |
Exit Print View | |
Sun Network QDR InfiniBand Gateway Switch HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Gateway
Assemble the Ethernet Splitter Data Cables
Install the Gateway in the Rack
Understanding Routing Through the Gateway
Identify All Switches in the Fabric
Identify All HCAs in the Fabric
Display the InfiniBand Fabric Topology (Simple)
Display the InfiniBand Fabric Topology (Detailed)
Display a Route Through the Fabric
Display Low-Level Detailed Information About a Node
Display Low-Level Detailed Information About a Port
Display the InfiniBand Fabric Partition Configuration
Display the InfiniBand Fabric Configuration
Perform Comprehensive Diagnostics for the Entire Fabric
Determine Changes to the InfiniBand Fabric Topology
Find 1x, SDR, or DDR Links in the Fabric
Determine Which Links Are Experiencing Significant Errors
Configuring the Fabric Director Node List
Fabric Director and Fabric Elements
Add or Remove an Element From the Fabric Configuration
Modify an Element of the Fabric Configuration
Exchange Master Fabric Director Status
Partitioning the InfiniBand Fabric
Remove User Partitions for Firmware Downgrade
Determine Partitions and P_Keys
Add or Remove a Port From a Partition
Administering Gateway Resources
Installing Gateway Supportive Software (Linux)
Creating VNICs Under Gateway Manual Mode (Linux)
Creating VNICs Under Host Manual Mode (Linux)
Creating Virtual IO Adapters (Oracle Solaris)
Controlling Gateway Ports and Parameters
Understanding Oracle ILOM on the Gateway
Upgrading the Gateway Firmware Through Oracle ILOM (CLI)
Upgrade the Gateway Firmware (Web)
Display Gateway Status LED States (IPMI)
Remove the Gateway From the Rack
If you want to know the link status of a node in the InfiniBand fabric, the ibportstate command can tell you the state, width, and speed of that node.
# ibportstate lid port
where:
lid is the LID of the node.
port is the port of the node.
For example:
# ibportstate 15 23 PortInfo: # Port info: Lid 15 port 23 LinkState:.......................Active PhysLinkState:...................LinkUp LinkWidthSupported:..............1X or 4X LinkWidthEnabled:................1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedActive:.................10.0 Gbps Peer PortInfo: # Port info: Lid 15 DR path slid 15; dlid 65535; 0,23 LinkState:.......................Active PhysLinkState:...................LinkUp LinkWidthSupported:..............1X or 4X LinkWidthEnabled:................1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkSpeedActive:.................10.0 Gbps #
In the output, the Active parameters are the current state of the port.
Gateway Reference, ibportstate command
