Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
This procedure is for removing a Switched NEM if you do not plan to replace it. If you plan to replace a NEM, see Replace a Switched NEM.
-> stop /CH/NEMn
where n is 0 through 1 for NEMs 0 or 1, respectively. For example:
-> stop /CH/NEM1
See Managing the NEM Remotely (ILOM) for more information on connecting to ILOM.
Support the weight of the NEM with one hand at the bottom of the NEM.
