Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
All mainboard voltage sensors are configured to generate the same events, and faults are handled in the same way.
This sensor monitors the voltage coming out of the 12V divider.
This sensor monitors the first fuse-protected input voltage coming from the chassis into the Switched NEM.
This sensor monitors a second fuse-protected input voltage coming from the chassis into the Switched NEM.
This sensor monitors the 1V main input that is active when the power is on.
This sensor monitors the 1.1V main input that is active when the power is on.
This sensor monitors the 1.2V main input that is active when the power is on.
This sensor monitors the 1.25V main input that is active when the power is on.
This sensor monitors the 1.5V main input that is active when the power is on.
This sensor monitors the 1.8V main input that is active when the power is on.
This sensor monitors the 3.3V main input that is active when the power is on.
This sensor monitors the 5V core input that is active when the power is on.
