Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
This figure shows the external ports on the Switched NEM, viewed from the back of the chassis.
Figure 1 Switched NEM Ports
Table 1 Switched NEM Components
Two SFP+ ports provide two 10 gigabit ethernet connections to external devices or a switch. The SFP+ ports support the following types of cables:
10 Gbyte/1 Gbyte dual speed fiber
1 Gbyte RJ-45 copper
10 Gbps direct attach copper
Three QSFP ports provide twelve 10 gigabit ethernet connections to external devices or a switch (four 10 gigabit ethernet connections for each port). The QSFP ports support the following types of cables:
4x10 Gbyte fiber SR
4x10 Gbyte to 4 SFP+ 10 Gbyte fiber SR
4x10 Gbyte direct attach copper
4x10 Gbyte to 4 SFP+ 10 Gbyte direct attach copper
A single RJ-45 serial management port provides connections to a system console.
The following table lists the pinout of the serial management connector.
