Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
In addition to the typical ILOM settings, /SP/clients/radius/fs_privilege has been added to allow and control SEFOS access by RADIUS users. This new attribute sets the default fs_privilege setting for all RADIUS users and supports the same values as can be set when creating an ILOM user account (1 for read only or 15 for full administrative privileges).
-> show /SP/clients/radius/ /SP/clients/radius Targets: Properties: address = 10.7.57.118 defaultrole = Operator fs_privilege = 1 port = 1812 secret = ***** state = enabled Commands: cd set show
The switch supports per-user settings for RADIUS users through Vendor Specific Attributes (VSA). Both the SEFOS administrative privilege level and the ILOM role can be set using per-user VSAs configured on the RADIUS server.
