Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
If a Switched NEM fails, you must replace it. The server modules must be informed if you are replacing a nonredundant NEM.
![]() | Caution - If the chassis is powered on and you are not replacing the NEM within 60 seconds, install an NEM filler panel to ensure proper system operation. |
-> stop /CH/NEMn
where n is 0 through 1 for NEMs 0 or 1, respectively. For example:
-> stop /CH/NEM1
See Managing the NEM Remotely (ILOM) for more information on connecting to ILOM.
Support the weight of the NEM with one hand at the bottom of the NEM.
See Install the Switched NEM for those instructions.
