Skip Navigation Links
Exit Print View
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE
User’s Guide
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Understanding the Switched NEM
Switched NEM Features Overview
Switched NEM External Ports
Switched NEM Internal Ports
Switched NEM LEDs
Installing or Replacing the Switched NEM
Install the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
SFP+ Cabling Guidelines
QSFP Cabling Guidelines
Remove a Switched NEM
Replace a Switched NEM
Managing the NEM Remotely (ILOM)
ILOM Overview
ILOM Documentation
ILOM Product Updates
ILOM Features Not Supported
Connecting to ILOM
ILOM Connection Options
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM
Connecting to the NEM ILOM Through the CMM ILOM
Connecting With SEFOS
SEFOS Overview
Connect to SEFOS
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
Understanding Sensors and Indicators
Presence Sensors
Switched NEM Indicators
Fan Threshold Sensors
Temperature Sensors
Voltage Sensors
Glossary
Index
The following QSFP cables are supported on the Sun Blade 6000 Ethernet Switched NEM 24p 10GbE:
Related Information
