Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configure an Externally Accessible IP Address on the NEM (Serial Connection and CLI)
Configure an Externally Accessible IP Address on the NEM (Ethernet and CLI)
Configure an Externally Accessible IP Address on the NEM (Ethernet and Web Interface)
Connect to the NEM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM (Ethernet and CLI)
Connect to the NEM ILOM (Serial Connection and CLI)
Connecting to the NEM ILOM Through the CMM ILOM
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and CLI)
Connect to the NEM ILOM Through the CMM ILOM (Serial Connection and CLI)
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
The procedures in this topic are necessary only if you are connecting to the NEM ILOM using one of the following connection methods:
You do not have to configure an externally accessible IP address on the NEM if you are connecting to the NEM ILOM using any other connection method.
Note that you will also need to configure an externally accessible IP address on the Switched NEM to use SNMP. Refer to the following documentation for more information on using SNMP with the Switched NEM:
Oracle Integrated Lights Out Manager (ILOM) 3.0 Management Protocols Reference Guide
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE Software Configuration Guide
The following topics describe the different methods for configuring an externally accessible IP address:
