Skip Navigation Links
Exit Print View
Sun Blade 6000 Ethernet Switched NEM 24p 10GbE
User’s Guide
search filter icon
search icon
Document Information
Using This Documentation
Related Documentation
CLI Command Modes
Feedback
Support and Accessibility
Understanding the Switched NEM
Switched NEM Features Overview
Switched NEM External Ports
Switched NEM Internal Ports
Switched NEM LEDs
Installing or Replacing the Switched NEM
Install the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
SFP+ Cabling Guidelines
QSFP Cabling Guidelines
Remove a Switched NEM
Replace a Switched NEM
Managing the NEM Remotely (ILOM)
ILOM Overview
ILOM Documentation
ILOM Product Updates
ILOM Features Not Supported
Connecting to ILOM
ILOM Connection Options
Configuring an Externally Accessible IP Address on the NEM
Configure an Externally Accessible IP Address on the NEM (Serial Connection and CLI)
Configure an Externally Accessible IP Address on the NEM (Ethernet and CLI)
Configure an Externally Accessible IP Address on the NEM (Ethernet and Web Interface)
Connecting to the NEM ILOM
Connect to the NEM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM (Ethernet and CLI)
Connect to the NEM ILOM (Serial Connection and CLI)
Connecting to the NEM ILOM Through the CMM ILOM
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and CLI)
Connect to the NEM ILOM Through the CMM ILOM (Serial Connection and CLI)
Connecting With SEFOS
SEFOS Overview
Connect to SEFOS
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
Understanding Sensors and Indicators
Presence Sensors
Switched NEM Indicators
Fan Threshold Sensors
Temperature Sensors
Voltage Sensors
Glossary
Index
  1. Verify that the terminal or terminal emulator has the correct settings.
    The terminal device can be an actual terminal, a laptop running a terminal emulator, or a terminal server. The terminal device must be set to the following:
    • 8N1: eight data bits, no parity, one stop bit
    • 9600 baud (default, can be set to any standard rate up to 57600)
    • Disable software flow control (XON/XOFF)
      The cable requires the following pin assignments.
      Pin
      Signal Description
      1
      Request To Send (RTS)
      2
      Data Terminal Ready (DTR)
      3
      Transmit Data (TXD)
      4
      Ground
      5
      Ground
      6
      Receive Data (RXD)
      7
      Data Set Ready (DSR)
      8
      Clear To Send (CTS)
  2. Connect a terminal or terminal emulator to the serial management port on the Switched NEM.
    See Switched NEM External Ports for the location of the serial management port on the Switched NEM.
  3. Press Enter on the terminal device.
    This action establishes the connection between the terminal device and the NEM ILOM.
    The ILOM login prompt appears.
    SUNSPnnnnnnnnnn login:
  4. Enter the user name and password when prompted.
    The default user is root and the default password is changeme.
    The ILOM prompt appears:
  5. Change directories to the network directory:
    -> cd SP/network
  6. Configure an externally accessible IP address on the Switched NEM:
    1. Set the pending IP address:
      -> set pendingipaddress=n.n.n.n
      Set ’pendingipaddress’ to ’n.n.n.n’
      For example:
      -> set pendingipaddress=10.7.59.97
      Set ’pendingipaddress’ to ’10.7.59.97’
    2. Set the pending IP gateway:
      -> set pendingipgateway=n.n.n.n
      Set ’pendingipgateway’ to ’n.n.n.n’
      For example:
      -> set pendingipgateway=10.7.59.254
      Set ’pendingipgateway’ to ’10.7.59.254’
    3. Set the pending IP netmask:
      -> set pendingipnetmask=n.n.n.n
      Set ’pendingipnetmask’ to ’n.n.n.n’
      For example:
      -> set pendingipnetmask=10.7.59.254
      Set ’pendingipnetmask’ to ’10.7.59.254’
    4. Commit the changes:
      -> set commitpending=true
      Set ’commitpending’ to ’true’
    5. Set the state to enabled:
      -> set state=enabled
      Set ’state’ to ’enabled’
  7. Verify the configuration information that you entered:
    -> show
    The CLI displays information about the Switched NEM, including its IP address.
    For example:
    -> show
     /SP/network
        Targets:
        Properties:
            type = Network Configuration
            commitpending = (Cannot show property)
            ipaddress = 10.7.59.97
            ipdiscovery = static
            ipgateway = 10.7.59.254
            ipnetmask = 255.255.255.0
            macaddress = 00:14:4f:6C:5D:E8
            pendingipaddress = 10.7.59.97
            pendingipdiscovery = static
            pendingipgateway = 10.7.59.254
            pendingipnetmask = 255.255.252.0
            state = enabled
        Commands:
            cd
            set
            show
  8. When you are done, exit the ILOM:
    -> exit
Related Information
