Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
In order to use the 10GbE functionality on the Sun Blade 6000 Ethernet Switched NEM 24p 10GbE, you must install certain fabric expansion modules on the server blade in the Sun Blade 6000 modular system. Refer to the Sun Blade 6000 Ethernet Switched NEM 24p 10GbE Product Notes for information on the server blades and fabric expansion modules that are supported with the Sun Blade 6000 Ethernet Switched NEM 24p 10GbE.
If a supported fabric expansion module has not been installed in one of the server blades in the Sun Blade 6000 modular system, follow the instructions that came with the module to do that now, then return here.
Refer to the documentation that came with the module for more information.
