Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
The following SFP+ cables are supported on the Sun Blade 6000 Ethernet Switched NEM 24p 10GbE:
10 Gbyte/1 Gbyte dual speed fiber
1 Gbyte RJ-45 copper
10 Gbps direct attach copper
The following table shows the OM MMF and SMF cabling options available for the Switched NEM SFP+ connectors.
Note - The optical transceiver for the Switched NEM uses a LC. The connection on the other side of the cable might use a different connector type.
![]() | Caution - Avoid putting unnecessary stress on the connection. Do not bend or twist the cable near the connectors, and avoid sharp cable bends of more than 90 degrees. |
