Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
The Switched NEM is automatically detected when the chassis is powered on.
See Managing the NEM Remotely (ILOM) for the different ways that you can connect to the NEM ILOM. This procedure assumes you are connecting to the NEM ILOM through the CMM ILOM (Ethernet and CLI).
Note - The examples in this section refer to NEM0. If you are installing NEM1, replace the “0” in these examples with “1”.
$ ssh ipaddress -l root
where ipaddress is the address of the CMM.
The default is changeme.
The CLI command prompt appears:
The NEM and the NEM FRU information appears in the CLI.
-> show /CH/NEM0 Targets: SEEPROM SP Properties: type = Network Express Module fru_name = SUN BLADE 6000 ETHERNET SWITCHED NEM 24p 10GbE fru_part_number = 501-7935-02 fru_serial_number = 0000000-7001C003K Commands: cd show
For more information about using CMM ILOM, see the ILOM documentation, at: http://docs.sun.com/app/docs/prod/blade.6000mod#hic
