Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
The Switched NEM is automatically detected when the chassis is powered on.
See Managing the NEM Remotely (ILOM) for the different ways that you can connect to the NEM ILOM. This procedure assumes you are connecting to the NEM ILOM through the CMM ILOM (Ethernet and Web Interface).
The ILOM login screen appears.
The default user is root and the default password is changeme.
The Component Management page appears.
If the Switched NEM does not appear in ILOM, verify that the NEM is properly seated in the chassis.
