Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Configure an Externally Accessible IP Address on the NEM (Serial Connection and CLI)
Configure an Externally Accessible IP Address on the NEM (Ethernet and CLI)
Configure an Externally Accessible IP Address on the NEM (Ethernet and Web Interface)
Connect to the NEM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM (Ethernet and CLI)
Connect to the NEM ILOM (Serial Connection and CLI)
Connecting to the NEM ILOM Through the CMM ILOM
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and CLI)
Connect to the NEM ILOM Through the CMM ILOM (Serial Connection and CLI)
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
Note - The Sun Blade 6000 Modular System chassis has its own instance of ILOM, called chassis monitoring module (CMM) ILOM, which is a separate entity from the NEM ILOM. The CMM ILOM is described in the Oracle Integrated Lights Out Manager (ILOM) 3.0 Supplement for Sun Blade 6000 and 6048 Modular System.
You can connect to the ILOM on your NEM using one of the following methods.
Note - The CMM ILOM in the chassis has an Ethernet switch that supports connections to the Switched NEMs and their respective ILOMs.
