Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Configure an Externally Accessible IP Address on the NEM (Serial Connection and CLI)
Configure an Externally Accessible IP Address on the NEM (Ethernet and CLI)
Connect to the NEM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM (Ethernet and CLI)
Connect to the NEM ILOM (Serial Connection and CLI)
Connecting to the NEM ILOM Through the CMM ILOM
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and CLI)
Connect to the NEM ILOM Through the CMM ILOM (Serial Connection and CLI)
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
The chassis view appears.
From the left navigation bar, select the NEM that you want to connect to.
Scroll over the graphical representation of the chassis and select the NEM that you want to connect to.
The NEM ILOM for that NEM appears.
The Network Settings page for the NEM appears.
In the State field, select Enabled.
In the IP Discovery Mode field, select Static.
Enter the IP Address, Netmask, and Gateway information in the appropriate fields.
