Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Configure an Externally Accessible IP Address on the NEM (Serial Connection and CLI)
Configure an Externally Accessible IP Address on the NEM (Ethernet and CLI)
Configure an Externally Accessible IP Address on the NEM (Ethernet and Web Interface)
Connect to the NEM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM (Ethernet and CLI)
Connect to the NEM ILOM (Serial Connection and CLI)
Connecting to the NEM ILOM Through the CMM ILOM
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and Web Interface)
Connect to the NEM ILOM Through the CMM ILOM (Ethernet and CLI)
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
Before You Begin
You must connect to the serial connector on the chassis CMM in order to connect to the chassis CMM ILOM. The CMM ILOM provides a command to connect to the NEM ILOM.
This action establishes the connection between the terminal device and the CMM ILOM.
The CMM ILOM login prompt appears.
SUNCMMnnnnnnnnnn login:
The default user is root and the default password is changeme.
Once you have successfully logged in, the CMM ILOM displays the ILOM default command prompt:
where n is 0 through 1 for NEMs 0 or 1, respectively.
A prompt appears.
If you typed y, the NEM ILOM prompts for its password.
Note - The CMM ILOM logs on to the NEM ILOM using the username in /CH/NEMn/SP/cli/user (where n is the NEM number). The default is root.
The NEM ILOM’s CLI interface appears. You are now connected to the NEM ILOM.
Go to Connect to SEFOS for those instructions.
