Understanding the Switched NEM
Switched NEM Features Overview
Installing or Replacing the Switched NEM
Verifying the Switched NEM Installation
Verify Installation With the CMM ILOM Web Interface
Verify Installation With the CMM ILOM CLI
Finish the Switched NEM Installation
Install the Fabric Expansion Module in the Server Blade
Installing or Removing SFP+ or QSFP Optical Transceiver Modules
Install an SFP+ or QSFP Optical Transceiver Module
Remove an SFP+ or QFSP Optical Transceiver Module
Managing the NEM Remotely (ILOM)
Configuring an Externally Accessible IP Address on the NEM
Connecting to the NEM ILOM Through the CMM ILOM
Configure SEFOS User Privileges
Special Considerations for RADIUS Users
Configure User Privileges for RADIUS Users
Backing Up and Restoring the ILOM and SEFOS Configuration
The ILOM tool enables you to actively manage the NEM, providing the same management look and feel found on Sun servers.
Remotely control the power state of the NEM
Connect to SEFOS
View the current status of sensors and indicators on the system
Determine the hardware configuration of your system
Receive generated alerts about system events in advance by using IPMI PETs, email alerts, and SNMP traps
Provides user management
Upgrade firmware for all components on the NEM through either the CLI or the Web interfaces
Configure standard ILOM services, such as the following:
Clock/NTP
Serial port
Network
Syslog
SNMP
Web server
SSH
IPMI
CLI
DNS
RADIUS
