This is a cold-service procedure that must be performed by qualified service personnel. Power down the server completely before performing this procedure.
![]() | Caution - This procedure requires that you handle components that are sensitive to ESD which can cause server components to fail. |
See Remove a Fan Module.
See Remove a DIMM.
![]() | Caution - When removing the ribbon cable from the motherboard, grasp the cable connector on either side and pull straight up to disconnect the cable. Do not rock the cable side to side. Doing so could damage the connector. |
Save the cables for use with the new fan board.
The circuit board and the fan holder portions of the fan board should remain together.
