Go to main content
SPARC T7-2 Server Service Manual
Exit Print View
Updated: July 2019
Power Off the Server (Oracle ILOM)
You can use the SPM to perform a graceful shutdown of the server, and to ensure that all of your data is saved and the server is ready for restart.
Note -  Additional information about powering off the server is provided in Servers Administration.
  1. Prepare to power off the server.
    See Prepare to Power Off the Server.
  2. Switch from the system console to the Oracle ILOM prompt by typing the #. (Hash-Dot) key sequence.
  3. Power off the server.
    -> stop /System
    Note -  You can also use the Server Power button on the front of the server to initiate a graceful server shutdown. (See Power Off the Server (Server Power Button - Graceful).) This button is recessed to prevent accidental server power-off.
Related Information
