Exit Print View
-> start /SP/faultmgmt/shell Are you sure you want to start /SP/faultmgmt/shell (y/n)? y faultmgmtsp>
If faults are reported, see Detecting and Managing Faults .
If no faults are reported, then the fan board has been replaced successfully.
Install the Fan Board
Remove the Fan Board
