Memory Riser
and DIMM FRU Names
This server includes eight memory risers. Four memory risers are associated with each CMP in
the server. A label is next to each memory riser that shows the number of the CMP and of
the riser. Four DIMM slots are on each memory riser.
DIMM FRU names are based on the location of the memory riser in the server, the DIMM slot on
the memory riser, and the CPU module associated with the memory riser. For example, the
full FRU name for the top-most DIMM slot
(BOB1/CH0/DIMM) on the first memory riser associated
with CPU module 0 (CM0/CMP/MR0) is:
/SYS/MB/CM0/CMP/MR0/BOB1/CH0/DIMM
CM0/MR0
/SYS/MB/CM0/CMP/MR0 (riser)
/SYS/MB/CM0/CMP/MR0/BOB0/CH0/DIMM
/SYS/MB/CM0/CMP/MR0/BOB0/CH1/DIMM
/SYS/MB/CM0/CMP/MR0/BOB1/CH1/DIMM |
Black
White
Black
White |
CM0/MR1 |
/SYS/MB/CM0/CMP/MR1 (riser)
/SYS/MB/CM0/CMP/MR1/BOB0/CH0/DIMM
/SYS/MB/CM0/CMP/MR1/BOB0/CH1/DIMM
/SYS/MB/CM0/CMP/MR1/BOB1/CH0/DIMM
/SYS/MB/CM0/CMP/MR1/BOB1/CH1/DIMM |
Black
White
Black
White |
CM0/MR2 |
/SYS/MB/CM0/CMP/MR2 (riser)
/SYS/MB/CM0/CMP/MR2/BOB0/CH0/DIMM
/SYS/MB/CM0/CMP/MR2/BOB0/CH1/DIMM
/SYS/MB/CM0/CMP/MR2/BOB1/CH0/DIMM
/SYS/MB/CM0/CMP/MR2/BOB1/CH1/DIMM |
Black
White
Black
White
CM0/MR3 |
/SYS/MB/CM0/CMP/MR3 (riser)
/SYS/MB/CM0/CMP/MR3/BOB0/CH0/DIMM
/SYS/MB/CM0/CMP/MR3/BOB0/CH1/DIMM
/SYS/MB/CM0/CMP/MR3/BOB1/CH0/DIMM
/SYS/MB/CM0/CMP/MR3/BOB1/CH1/DIMM |
Black
White
Black
White
CM1/MR0 |
/SYS/MB/CM1/CMP/MR0 (riser)
/SYS/MB/CM1/CMP/MR0/BOB0/CH0/DIMM
/SYS/MB/CM1/CMP/MR0/BOB0/CH1/DIMM
/SYS/MB/CM1/CMP/MR0/BOB1/CH0/DIMM
/SYS/MB/CM1/CMP/MR0/BOB1/CH1/DIMM |
Black
White
Black
White
CM1/MR1 |
/SYS/MB/CM1/CMP/MR1 (riser)
/SYS/MB/CM1/CMP/MR1/BOB0/CH0/DIMM
/SYS/MB/CM1/CMP/MR1/BOB0/CH1/DIMM
/SYS/MB/CM1/CMP/MR1/BOB1/CH0/DIMM
/SYS/MB/CM1/CMP/MR1/BOB1/CH1/DIMM |
Black
White
Black
White
CM1/MR2 |
/SYS/MB/CM1/CMP/MR2 (riser)
/SYS/MB/CM1/CMP/MR2/BOB0/CH0/DIMM
/SYS/MB/CM1/CMP/MR2/BOB0/CH1/DIMM
/SYS/MB/CM1/CMP/MR2/BOB1/CH0/DIMM
/SYS/MB/CM1/CMP/MR2/BOB1/CH1/DIMM |
Black
White
Black
White
CM1/MR3 |
/SYS/MB/CM1/CMP/MR3 (riser)
/SYS/MB/CM1/CMP/MR3/BOB0/CH0/DIMM
/SYS/MB/CM1/CMP/MR3/BOB0/CH1/DIMM
/SYS/MB/CM1/CMP/MR3/BOB1/CH0/DIMM
/SYS/MB/CM1/CMP/MR3/BOB1/CH1/DIMM |
Black
White
Black
White
