This is a cold-service procedure that must be performed by qualified service personnel. Power down the server completely before performing this procedure.
![]() | Caution - This procedure requires that you handle components that are sensitive to ESD which can cause server components to fail. |
When replacing the motherboard, remove the SPM and SCC PROM from the old motherboard and install these components on the new motherboard. The SPM contains the Oracle ILOM system configuration data, and the SCC PROM contains the system host ID and MAC address. Transferring these components preserves the system-specific information stored on these modules. Whenever you replace the motherboard or the SPM, you must update the firmware so the portions of firmware in the SPM and on the motherboard are consistent.
See Prevent ESD Damage.
Ensure that remaining cables do not get caught on edges of the motherboard.
Set the motherboard towards the front of the chassis, then slide it toward the rear of the chassis.
Using a No. 2 screwdriver, tighten the bus bar screws until the PS backplane and the motherboard securely fasten to the bus bars.
Ensure that the tooth at the bottom of the cover is clear of the power supply cage.
You must guide two slots on the PS backplane cover around two pins on the inside of the power supply cage.
![]() | Caution - When connecting the ribbon cable to the motherboard, take care to center the cable on the connector before inserting the cable. |
One cable goes to the drive backplane. The other is a ribbon cable to the power supply.
![]() | Caution - When connecting the ribbon cable to the drive backplane, take care to center the cable on the connector before inserting the cable. |
Install cables to their original positions.
![]() | Caution - After replacing the motherboard, inspect the gasket on the air divider before installing the air divider securely. This dividing wall maintains a pressurized seal between the server cooling zones. Without this pressurized seal, the power supply fans will not be able to draw enough air to cool the drives properly. |
See Install the SPM.
See Attach Power Cords.
Refer to Server Installation for instructions.
The SPM detects the host firmware on the replacement motherboard is not compatible with the existing SPM firmware, further action will be suspended and the following message will be displayed:
Unrecognized Chassis: This module is installed in an unknown or unsupported chassis. You must upgrade the firmware to a newer version that supports this chassis.
If necessary, configure the server's NET MGT port so that it can access the network. Log in to the SPM through the NET MGT port.
Refer to the Oracle ILOM documentation for network configuration instructions.
Follow the firmware download instructions in the Oracle ILOM documentation.
If your server contained RAID volumes prior to replacing the motherboard, see Reactivate RAID Volumes for instructions.
See Power On the Server (Oracle ILOM) or Power On the Server (System Power Button).
If the replacement motherboard must have the same serial number as the server prior to servicing, trained service personnel must take this action in a special service mode.
