Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Dumps target information to a remote location.
dump [-destination URI][target]
where:
URI is the uniform resource indicator.
target is the target and path to act upon.
This Oracle ILOM command transfers target information to a remote location specified by the URI. If no target is specified, the current target is affected. Your user must have administrator (a) privileges to use this command. The -destination option specifies the location. If the -destination option is not used, then the information is transferred to stdout.
This example shows how to transfer the /SP/services/snmp/mibs target information to the ilom-mibs.zip file on the host with IP address 123.45.67.89 using the FTP protocol with the dump command.
-> dump -destination ftp://root:changeme@123.45.67.89/tftpboot/ilom-mibs.zip /SP/services/snmp/mibs ->
