Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Defines fabric elements monitored through the FabricMIB.
fdconfig sub-command [-h]
This hardware command has sub-commands that determine its functionality. This table describes the sub-commands and provides their syntax.
where:
name is the identifier of the fabric or element (can be host name).
IP_address is the IP address of an element.
type is the identifer of the type of element:
sw36 – Sun Datacenter InfiniBand Switch 36
sw36gw – Sun Network QDR InfiniBand Gateway Switch
unknown – The element’s type is unknown.
role is the purpose of the element:
gateway – The element acts as a gateway.
spineSwitch – The element acts as a spine switch.
leafSwitch – The element acts as a leaf switch.
unknown – The element’s role is unknown.
This hardware command is used to configure a list of InfiniBand devices expected to be in the fabric. The Fabric Director node list file is used by the Fabric Directors to compile fabric MIBs that describe the InfiniBand fabric. For the file, InfiniBand devices are referred to as elements, and each internal element hosts a Fabric Director. Elements can be:
internal – switches
external – HCAs and TCAs
gateway – BridgeX chips
Similar to Subnet Managers, there can only be one active master Fabric Director for a given InfiniBand fabric.
The fdconfig command is available from the /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
Note - At this time, the fdconfig command is available to only the root user.
This table describes the options to the fdconfig command and their purposes.
This example shows how to list the current fabric configuration with the fdconfig command.
Note - The output for your InfiniBand fabric will differ from that in the example.
# fdconfig list-current-fabric-config Name IP Addr Type Role(s) isMaster Fabricname -------------------------------- ---------------- ------ -------------------- -------- ---------- primary 10.172.144.66 sw36 leafSwitch yes test secondary 10.172.144.70 sw36gw gateway no test #
