Skip Navigation Links
Exit Print View
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Installation
Understanding the Switch
Switch Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
Network Management Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Switch
Installation Preparation
Installation Responsibilities
Installation Sequence
Route the Data Cables
Installing the Switch
Install the Switch in the Rack
Powering On the Switch
Connecting Data cables
Administration
Troubleshooting the Switch
Switch Hardware Problems
InfiniBand Fabric Problems
Identifying LEDs
Understanding Routing Through the Switch
Switch GUIDs Overview
Configuration Overview
Hardware Command Overview
InfiniBand Command Overview
ILOM Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Remote Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Overview
Supported Features
Installing the Oracle ILOM Firmware
Firmware Delivery
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
CLI Overview
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Upgrade the Switch Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Switch Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (ILOM)
help Command (ILOM)
load Command
reset Command
set Command
show Command
version Command (ILOM)
Service
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Identify the Data Cable
Inspect the Data Cable Hardware
Inspect the Data Cable Connectors
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Remove the Switch From the Rack
Replace the Battery
Reference
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
dcsport Command
disablecablelog Command
disablelinklog Command
disablesm Command
disableswitchport Command
enablecablelog Command
enablelinklog Command
enablesm Command
enableswitchport Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportstatus Command
help Command (Hardware)
listlinkup Command
matchtopology Command
setcontrolledhandover Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsubnetprefix Command
showfruinfo Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
Before installing a data cable, inspect its hardware and connectors to verify its suitability for installation.
Step
Description
Links
1.
Identify the cable.
2.
Inspect the hardware.
3.
Inspect the connectors
Related Information
