Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
The preferred method of accessing the Linux shell is through the /SYS/Switch_Diag, and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
Using the show command on the /SYS/Switch_Diag target opens a restricted Linux shell that enables the ilom-admin user, ilom-operator user, and users with similar permissions to run diagnostic commands.
Using the show command on the /SYS/Fabric_Mgmt target opens an other restricted Linux shell that enables the ilom-admin user and users with similar permissions to run diagnostic, switch, and fabric management commands.
Note - The ilom-operator user cannot access the Linux shell from the /SYS/Fabric_Mgmt target.
This table lists the hardware commands and their availability from the respective Linux shell targets. Typing the help all command from within the restricted shells lists the commands available to that shell.
Note - Hardware commands that are not listed are unavailable from the /SYS/Switch_Diag or /SYS/Fabric_Mgmt targets.
