Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Sets the subnet prefix.
setsubnetprefix prefix|list
where prefix is the hexadecimal prefix.
This hardware command sets the subnet prefix for the InfiniBand fabric. The prefix is entered in hexadecimal, starting with 0x and having lower case alphanumeric characters. The list option provides a listing of the Subnet Manager settings in respect to priority, controlled handover, and subnet prefix.
The setsubnetprefix command writes the value of prefix to the subnet_prefix parameter of the configuration file.
Note - You must stop or disable the Subnet Manager before using the setsubnetprefix command. See disablesm Command.
The setsubnetprefix command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to set the subnet prefix to 0xabbababe with the setsubnetprefix command.
# setsubnetprefix 0xabbababe Current SM settings: smpriority 5 controlled_handover TRUE subnet_prefix 0xabbababe M_Key None #
