Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Queries InfiniBand port counters.
perfquery [-d][-e][-G][-h][-a][-l][-r][-R][-v][-V][-C ca_name][-P ca_port][-t timeout][lid|guid [[port][reset_mask]]]
where:
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
lid is the local identifier.
guid is the global unique identifier.
port is the port being queried.
reset_mask is the two-byte mask.
This InfiniBand command uses the performance management GMPs to acquire the PortCounters or PortExtendedCounters from the Performance Manager agent at the node or port specified.
Note - The data values retrieved from PortCounters and PortExtendedCounters are represented as octets divided by 4.
Note - Providing a port value of 255 ensures that the operation is performed on all ports.
The perfquery command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the perfquery command and their purposes.
This example shows how to display all port counters for LID 15, port 28 with the perfquery command.
# perfquery 15 28 # Port counters: Lid 15 port 28 PortSelect:......................28 CounterSelect:...................0x1b01 SymbolErrors:....................0 . . . VL15Dropped:.....................0 XmtData:.........................33791184 RcvData:.........................33789168 XmtPkts:.........................469322 RcvPkts:.........................469294 #
perfquery man page
