Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Queries InfiniBand switch forwarding tables.
ibroute [-d][-a][-n][-D][-e][-G][-h][-M][-s smlid][-v][-V][-C ca_name][-P ca_port][-t timeout][lid|dr_path|guid [startlid [endlid]]]
where:
smlid is the Subnet Manager LID.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
lid is the local identifier.
dr_path is the directed path.
guid is the global unique identifier.
startlid is the starting local identifier.
endlid is the ending local identifier.
This InfiniBand command uses SMPs to display the forwarding tables for the specified switch LID and optionally, the LID range. By default, the range is all valid entries from 1 to FDBTop.
The ibroute command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibroute command and their purposes.
This example shows how to display the forwarding table for LID 15 with the ibroute command.
Note - The output for your InfiniBand fabric will differ from that in the example.
# ibroute 15 Unicast lids [0x0-0xf] of switch Lid 15 guid 0x0021283a8389a0a0 (Sun DCS 36 QDR switch localhost): Lid Out Destination Port Info 0x000e 023 : (Channel Adapter portguid 0x0003ba000100e38a: ’mnm33-43 HCA-1’) 0x000f 000 : (Switch portguid 0x0021283a8389a0a0: ’Sun DCS 36 QDR switch localhost’) 2 valid lids dumped #
ibroute man page
