Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Note - Perform this task only if your firmware version number is earlier than 1.1.3.
Note - This procedure brings the management controller offline until after the upgrade is completed.
Caution - The firmware upgrade completely erases the management controller’s file system. |
# disablesm Stopping partitiond daemon. [ OK ] Stopping IB Subnet Manager.. [ OK ] #
# cd /tmp # sh spfw_upgrade_1.1.3.sh http://URL_to_directory #
where URL_to_directory is a URL that points to the directory on the web server that contains the unpacked .rpm files from the SUN_DCS_36p_1.1.3.tar file.
The upgrade begins.
# reboot
# version SUN DCS 36p version: 1.1.3 Build time: Mar 25 2010 10:00:23 SP board info: Manufacturing Date: 2009.02.19 Serial Number: "NCD2S0133" Hardware Revision: 0x0100 Firmware Revision: 0x0102 BIOS version: NOW1R112 BIOS date: 04/24/2009 #
# enablesm Starting IB Subnet Manager. [ OK ] Starting partitiond daemon. [ OK ] #
See Upgrading the Switch Firmware Through Oracle ILOM (CLI) or Upgrade the Switch Firmware (Web).
