Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Manages the Subnet Manager nodes file.
smnodes add IP_address [IP_address ...]|delete IP_address [IP_address ...]|list
where IP_address is the IP address of the Subnet Manager nodes.
This hardware command adds to , deletes from , or lists the Subnet Manager nodes of the Subnet Manager nodes file. The file is used when partitioning the InfiniBand fabric, to make partition managers aware of each other.
The smnodes command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to list the Subnet Manager nodes of the file with the smnodes command.
# smnodes list 123.45.67.89 123.45.67.90 #
