Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Disables a connector or switch chip port.
disableswitchport [--reason=reason] connector|ibdev port
where:
reason is the reason for disabling the port, Blacklist or Partition.
connector is the number of the QSFP connector (0A–17B).
ibdev is the InfiniBand device name (Switch)
port is the number of the port (1–36).
This hardware command disables a QSFP connector and port on the switch chip. The command addresses either the connector or the port on the switch chip.
The --reason option enables you to use a passphrase to lock the state of the port:
Blacklist – A connector and port pair are identified as being inaccessible because of unreliable operation.
Partition – A connector and port pair are identified as being isolated from the InfiniBand fabric.
Both the Blacklist and Partition passphrases survive reboot. You unlock these passphrases using the enableswitchport command with the --reason option.
The disableswitchport command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to disable and blacklist connector 14A with the disableswitchport command.
# disableswitchport --reason=Blacklist 14A Disable connector 14A Switch port 7 reason: Blacklist MKEY 8 0000000000000000 Adminstate:......................Disabled LinkWidthEnabled:................1X or 4X LinkWidthSupported:..............1X or 4X LinkWidthActive:.................4X LinkSpeedSupported:..............2.5 Gbps or 5.0 Gbps or 10.0 Gbps LinkState:.......................Down PhysLinkState:...................Disabled LinkSpeedActive:.................2.5 Gbps LinkSpeedEnabled:................2.5 Gbps or 5.0 Gbps or 10.0 Gbps #
