Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Servicing the switch means a component addition, replacement, or subtraction.
A component addition means installing a component to increase the functionality of the switch. Component replacement means removing a failed component and installing a functional one. Component subtraction means removing a component.
Once a failed part is identified, it can be replaced. The topics listed here help you service switch chassis components.
