Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Creates topology file.
generatetopology topofile|[-h]
where topofile is the filename and path to the topology file.
This hardware command creates a topology file of the InfiniBand fabric. This file is not compatible with the topology file created by the ibnetdiscover command. The generatetopology command is used with the matchtopology and showtopology commands to determine changes in the InfiniBand fabric. The -h option provides help.
The generatetopology command is available from the /SYS/Fabric_Mgmt Linux shell target of the Oracle ILOM CLI interface.
This example shows how to create a topology file called Topo.conf with the generatetopology command.
# generatetopology AUG22.topo It will take some time to generate a topology file. Please wait! topo.conf file is created. Will now start generating the topo file Wrote Topology file: AUG22.topo #
This is a portion of a topology file created by the generatetopology command.
Note - Your topology file will differ.
DEV26418_02P mnm34-45_HCA-1 P1 -4x-10G-> SUNDCS36QDR mnm34-170 C-0A P2 -4x-10G-> SUNDCS36QDR mnm34-170 C-0B SUNDCS36QDR mnm34-170 P1 -4x-10G-> SUNIBQDRGW mnm34-97 C-7A P2 -4x-10G-> I4_GENERIC mnm34-98 P33 SUNIBQDRGW mnm34-97 C-17A -4x-10G-> SUNDCS36QDR mnm34-170 C-17B C-17B -4x-10G-> SUNDCS36QDR mnm34-170 C-17A C-16A -4x-10G-> SUNDCS36QDR mnm34-170 C-16B C-16B -4x-10G-> SUNDCS36QDR mnm34-170 C-16A C-15A -4x-10G-> SUNDCS36QDR mnm34-170 C-15B C-15B -4x-10G-> SUNDCS36QDR mnm34-170 C-15A C-14A -4x-10G-> SUNDCS36QDR mnm34-170 C-13A C-14B -4x-10G-> SUNDCS36QDR mnm34-170 C-8A . . . DEV26418_02P mnm34-39_HCA-1 P1 -4x-10G-> SUNDCS36QDR mnm34-170 C-12A P2 -4x-10G-> SUNDCS36QDR mnm34-170 C-13B # Created from mnm34-170 at Wed Sep 8 14:18:52 CEST 2010
