Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Displays InfiniBand switch node in the topology.
ibswitches [-h][topology|-C ca_name][-P ca_port][-t timeout]
where:
topology is the topology file.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
This InfiniBand command is a script the discovers the InfiniBand fabric topology or uses an existing topology file to extract the switch nodes.
The ibswitches command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibswitches command and their purposes.
This example shows how to display the switch GUIDs with the ibswitches command.
Note - The output for your InfiniBand fabric will greatly differ from that in the example.
# ibswitches Switch : 0x03ba01234567a0a0 ports 36 "SUN DCS 36P QDR mnm-36p-2 10.172.144.66" enhanced port 0 lid 1 lmc 0 Switch : 0x002128312345c0a0 ports 36 "SUN IB QDR GW switch mnm-gw-1 10.172.144.69" enhanced port 0 lid 15 lmc 0 #
ibswitches man page
