Skip Navigation Links
Exit Print View
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0
search filter icon
search icon
Document Information
Using This Documentation
Product Notes
Related Documentation
Feedback
Support and Accessibility
Installation
Understanding the Switch
Switch Overview
Physical Specifications
Environmental Requirements
Acoustic Noise Emissions
Electrical Specifications
Network Management Connector and Pins
Data QSFP Connector and Pins
Understanding Cabling
Routing Service Cables
Understanding Data Cabling
Preparing to Install the Switch
Installation Preparation
Installation Responsibilities
Installation Sequence
Route the Data Cables
Installing the Switch
Install the Switch in the Rack
Powering On the Switch
Connecting Data cables
Administration
Troubleshooting the Switch
Switch Hardware Problems
InfiniBand Fabric Problems
Identifying LEDs
Understanding Routing Through the Switch
Switch GUIDs Overview
Configuration Overview
Hardware Command Overview
InfiniBand Command Overview
ILOM Command Overview
Administering the Chassis
Monitoring the Chassis
Controlling the Chassis
Monitoring the I4 Switch Chip
Monitoring the Subnet Manager
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Remote Management
Understanding Oracle ILOM on the Switch
Oracle ILOM Overview
Supported Features
Installing the Oracle ILOM Firmware
Firmware Delivery
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
CLI Overview
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Web Interface Overview
Performing Daily Tasks (Web)
Display the Date (Web)
Display the Switch Status LEDs States (Web)
Display the Aggregate Sensors State (Web)
Display Power Supply Status (Web)
Display Board-Level Voltages (Web)
Display Internal Temperatures (Web)
Display Fan Status (Web)
Display the Oracle ILOM Sessions (Web)
Display the Oracle ILOM Event Log (Web)
Checking the Status of Services (Web)
Display the HTTP Service Status (Web)
Display the HTTPS Service Status (Web)
Display the SSL Certificates (Web)
Display the SNMP Service Status (Web)
Display the SNMP Service User Accounts (Web)
Display the SNMP Service Communities (Web)
Display the IPMI Service Status (Web)
Display the DNS Client Status (Web)
Display the SMTP Client Status (Web)
Display the Network Time Protocol Servers (Web)
Verifying Other Aspects With Oracle ILOM (Web)
Display the Alert Properties (Web)
Display the Oracle ILOM User Accounts (Web)
Display the Remote Log Hosts (Web)
Display the Network Management Configuration (Web)
Display the CLI Session Timeout (Web)
Display System Component FRU ID (Web)
Display the Firmware Version (Web)
Display System Identification Properties (Web)
Performing General Tasks on Oracle ILOM Targets (Web)
Restart the Management Controller (Web)
Set the Date and Time (Web)
Set the Time Zone (Web)
Enable the Locator LED (Web)
Disable the Locator LED (Web)
Clear the Oracle ILOM Event Log (Web)
Set the Remote Log Hosts (Web)
Configure the DNS Client (Web)
Configure the SMTP Client (Web)
Back Up the Configuration (Web)
Restore the Configuration (Web)
Create a Snapshot of the Switch State (Web)
Snapshot Dataset Information (Web)
Set the Network Management Parameters (Web)
Set the System Identification Properties (Web)
Performing Oracle ILOM User Tasks (Web)
Add an Oracle ILOM User Account (Web)
Change an Oracle ILOM User’s Password and or Role (Web)
Delete an Oracle ILOM User Account (Web)
Managing HTTP Services (Web)
Enable the HTTP Service (Web)
Disable the HTTP Service (Web)
Managing HTTPS Services (Web)
Enable the HTTPS Service (Web)
Install a Custom SSL Certificate (Web)
Remove the Custom SSL Certificate (Web)
Disable the HTTPS Service (Web)
Managing SNMP Services (Web)
Enable the SNMP Service (Web)
Configure the SNMP Service (Web)
Add SNMP Service User Accounts (Web)
Modify SNMP Service User Accounts (Web)
Delete SNMP Service User Accounts (Web)
Add SNMP Service Communities (Web)
Modify SNMP Service Communities (Web)
Delete SNMP Service Communities (Web)
Download SNMP Service MIBs (Web)
Disable the SNMP Service (Web)
Managing IPMI Services (Web)
Enable the IPMI Service (Web)
Disable the IPMI Service (Web)
Managing Other Aspects With Oracle ILOM (Web)
Enable Alerts to Send SNMP Traps (Web)
Enable Alerts to Send PETs (Web)
Enable Alerts to Send Email Alerts (Web)
Disable Alerts (Web)
Set the CLI Session Timeout (Web)
Upgrade the Switch Firmware (Web)
Using the Fabric Monitor
Access the Fabric Monitor
Fabric Monitor Features
Control Panel Function
SNMP Overview
Understanding SNMP Commands
Administering Hardware (IPMI)
ipmitool Overview
Display Switch Status LED States (IPMI)
Enable the Locator LED (IPMI)
cd Command
create Command
delete Command
dump Command
exit Command (ILOM)
help Command (ILOM)
load Command
reset Command
set Command
show Command
version Command (ILOM)
Service
Replaceable Components
Suggested Tools for Service
Servicing Power Supplies
Inspecting a Power Supply
Power Off a Power Supply
Remove a Power Supply
Install a Power Supply
Power On a Power Supply
Servicing Fans
Inspecting a Fan
Remove a Fan
Install a Fan
Servicing Data Cables
Inspecting the Data Cables
Remove a Data Cable
Install a Data Cable
Servicing the Battery
Remove the Switch From the Rack
Replace the Battery
Reference
checkboot Command
checkpower Command
checktopomax Command
checkvoltages Command
connector Command
dcsport Command
disablecablelog Command
disablelinklog Command
disablesm Command
disableswitchport Command
enablecablelog Command
enablelinklog Command
enablesm Command
enableswitchport Command
env_test Command
exit Command (Hardware)
fdconfig Command
fwverify Command
generatetopology Command
getfanspeed Command
getmaster Command
getportstatus Command
help Command (Hardware)
listlinkup Command
matchtopology Command
setcontrolledhandover Command
setmsmlocationmonitor Command
setsmmkey Command
setsmpriority Command
setsubnetprefix Command
showfruinfo Command
showpsufru Command
showsmlog Command
showtemps Command
showtopology Command
showunhealthy Command
smconfigtest Command
smnodes Command
smpartition Command
version Command (Hardware)
ibdiagnet Command
ibhosts Command
ibnetdiscover Command
ibnetstatus Command
ibnodes Command
ibportstate Command
ibroute Command
ibrouters Command
ibstat Command
ibswitches Command
ibtracert Command
perfquery Command
saquery Command
smpquery Command
Understanding SNMP MIB OIDs
OID Tables Overview
Understanding the ENTITY-MIB MIB OIDs
Index
Note - If you are going to downgrade the firmware to a version earlier than 2.0, you must remove user partitions and depopulate the Subnet Manager nodes list. See Switch Administration, removing partitions for firmware downgrade.
  1. Acquire the firmware package.
    See Acquire the Switch Firmware Package (CLI).
  2. Open an SSH session and connect to the management controller by specifying the controller’s host name.
    For example:
    % ssh -l root nm2name
    root@nm2name’s password: password
    where nm2name is the host name of the management controller. Initially, the password is changeme.
  3. If the Subnet Manager is running on the management controller, disable it with the disablesm command.
    # disablesm
    Stopping partitiond daemon.                                [  OK  ]
    Stopping IB Subnet Manager..                               [  OK  ]
  4. Verify that there is at least 80 MB available in the / filesystem.
    # df -m /
    Filesystem           1M-blocks      Used Available Use% Mounted on
    /dev/hda2                  471     287     161     65%     /
    In this example, there are 161 MB available. If not enough space is available, you must delete or move files from the / filesystem.
  5. Verify that there is at least 120 MB available in the /tmp directory.
    # df -h /tmp
    Filesystem            Size  Used Avail Use% Mounted on
    tmpfs                 250M  240K 249M 1% /tmp
    In this example, there are 249 MB available. If not enough space is available, you must delete files from the /tmp directory.
  6. If you will perform a local file upload, perform these steps.
    Otherwise, go to Step 7.
    1. Verify that there is at least 120 MB available in the /dev/shm directory.
      # df -h /dev/shm
      tmpfs                 250M   16K  250M   1% /dev/shm
      In this example, there are 250 MB available. If not enough space is available, you must delete or move files from the /dev/shm directory.
    2. Verify that there is at least 240 MB free memory available.
      # free -m
                       total       used       free     shared    buffers     cached
      Mem:           498        104        393          0         12         47
      -/+ buffers/cache:         45        453
      Swap:            0          0          0
      In the -/+ buffers/cache: row of the free column, there should be at least 240 MB free memory. In this example, there are 453 MB available. If not enough memory is available, you must exit non-essential applications that are running.
    3. Go to Step 8.
  7. Verify that there is at least 120 MB free memory available.
    # free -m
    Swap:            0          0          0
    In the -/+ buffers/cache: row of the free column, there should be at least 120 MB free memory. In this example, there are 453 MB available. If not enough memory is available, you must exit nonessential applications that are running.
  8. Access the Oracle ILOM web interface.
    See Access Oracle ILOM From the Web Interface.
  9. Click the Maintenance tab.
  10. Click the Firmware Upgrade subtab.
    The Firmware Upgrade window opens.
  11. Click Enter Upgrade Mode.
    A dialog box opens and asks you to confirm.
  12. Click OK.
    The Firmware Upgrade window changes to Upgrade mode and now accepts either a local file path and file name, or a URL and file name of the switch firmware package.
  13. Consider your next step:
    • # If you are performing a local file upload, click Browse and locate the file.
    • # If the switch firmware package is located remotely, click Specify URL and type the fully qualified URL for the package.
    Note - Clicking Specify URL also changes the button to Local File Upload. Clicking Local File Upload changes the button back to Specify URL.
    Note - For the specified URL, only the FTP or HTTP protocols are supported.
  14. Click Upload.
    Oracle ILOM transfers the switch firmware package to the management controller. Oracle ILOM verifies the package integrity and displays the current versions of the firmware and versions in the package.
  15. Click Start Upgrade.
  16. Click OK.
    The upgrade begins and the status of the upgrade is reported.
    When the upgrade process ends, a log and summary report are displayed.
  17. Click OK.
    A final status is displayed, the upgrade either:
    • Succeeded
    • Partially succeeded
    • Failed
  18. Reboot the switch to enable the new firmware.
    See Switch Administration, restarting the entire switch.
    Note - The restart process takes between 4 to 5 minutes to complete. The Oracle ILOM stack requires at least 2 minutes to become operational after a reboot.
  19. If the Subnet Manager was previously disabled, open an SSH session, connect to the management controller, and enable the Subnet Manager.
    % ssh -l root switch_name
    root@switch_name’s password: password
    # enablesm
    Starting IB Subnet Manager.                                [  OK  ]
    Starting partitiond daemon.                                [  OK  ]
    # exit
  20. Access the Oracle ILOM web interface.
  21. Verify the success of the firmware update.
    See Display the Firmware Version (Web).
  22. Verify the firmware integrity.
    See Verify Firmware Integrity (CLI).
Related Information
