Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Displays host nodes.
ibhosts [-h][topology|-C ca_name][-P ca_port][-t timeout]
where:
topology is the topology file.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
This InfiniBand command is a script that discovers the InfiniBand fabric topology or uses the existing topology file to extract the channel adapter nodes.
The ibhosts command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibhosts command and their purposes.
This example shows how to display the host node GUIDs with the ibhosts command.
Note - The output in the example is a portion of the full output and varies for each InfiniBand topology.
# ibhosts Ca : 0x00212800013e9312 ports 2 "mnm56 HCA-1" Ca : 0x00212800013e93f6 ports 2 "mnm57 HCA-1" Ca : 0x002128312345c000 ports 2 "SUN IB QDR GW switch mnm-gw-1 10.172.144.69 Bridge 0" Ca : 0x002128312345c040 ports 2 "SUN IB QDR GW switch mnm-gw-1 10.172.144.69 Bridge 1" . . . #
ibhosts man page
