Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Traces the InfiniBand path.
ibtracert [-d][-D][-G][-h][-m mlid][-s smlid][-v][-V][-C ca_name][-P ca_port][-t timeout][lid|dr_path|guid [startlid [endlid]]]
where:
mlid is the multicast LID.
smlid is the Subnet Manager LID.
ca_name is the channel adapter name.
ca_port is the channel adapter port.
timeout is the timeout in milliseconds.
lid is the local identifier.
dr_path is the directed path.
guid is the global unique identifier.
startlid is the starting LID for a range.
endlid is the ending LID for a range.
This InfiniBand command uses SMPs to trace the path from a source GID or LID to a destination GID or LID. Each responding hop in the path is displayed. The -m option enables multicast path tracing between source and destination nodes.
The ibtracert command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the ibtracert command and their purposes.
This example shows how to display the path from LID 15 to LID 14 with the ibtracert command.
Note - The output for your InfiniBand fabric will differ from that in the example.
# ibtracert 15 14 From switch {0x0021283a8389a0a0} portnum 0 lid 15-15 "Sun DCS 36 QDR switch localhost" [23] -> ca port {0x0003ba000100e38a}[2] lid 14-14 "mnm-43 HCA-1" To ca {0x0003ba000100e388} portnum 2 lid 14-14 "mnm-43 HCA-1" #
ibtracert man page
