Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Displays the Subnet Manager log.
showsmlog [-h]
This hardware command displays the log entries for the Subnet Manager within the management controller. Tapping the space bar displays the next screen of the log. Pressing the Q key quits. The -h option provides help.
The showsmlog command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the Subnet Manager log with the showsmlog command.
Note - The output of the example is a very small portion and will differ from your output.
# showsmlog Jun 30 14:44:11 008981 [B6694B90] 0x02 -> osm_ucast_mgr_process: minhop tables configured on all switches Jun 30 14:44:11 011981 [B6694B90] 0x02 -> SUBNET UP Jun 30 14:44:11 025981 [B6694B90] 0x02 -> Fabric has 1 switches - topology is not fat-tree. Falling back to default routing Jun 30 14:44:11 025981 [B6694B90] 0x01 -> ucast_mgr_route: ftree: cannot build lid matrices. Jun 30 14:44:11 025981 [B6694B90] 0x02 -> osm_ucast_mgr_process: minhop tables configured on all switches Jun 30 14:44:11 027981 [B6694B90] 0x02 -> SUBNET UP . . .
