Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Maps between switch chip ports and QSFP connectors.
dcsport [-guid guid|-type DCS-36p -ibdev ibdev] -port port|-connector connector|-printconnectors
where:
guid is the global unique identifier.
ibdev is the InfiniBand device name (Switch)
port is the number of the port (1–36).
connector is the name of the connector (0A – 17A or 0B – 17B).
This hardware command displays the mapping between I4 switch chip ports and QSFP connectors. You can specify either a port or a connector.
The dcsport command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This table describes the options to the dcsport command and their purposes.
Note - If no guid or ibdev are specified, the command defaults to the local I4 switch chip.
This example shows how to display the mapping for port 7 with the dcsport command.
# dcsport -port 7 DCS-36P Switch port 7 maps to connector 14A #
