Skip Navigation Links | |
Exit Print View | |
Sun Datacenter InfiniBand Switch 36 HTML Document Collection for Firmware Version 2.0 |
Network Management Connector and Pins
Preparing to Install the Switch
Install the Switch in the Rack
Understanding Routing Through the Switch
Configuring the Fabric Director Node List
Partitioning the InfiniBand Fabric
Understanding Oracle ILOM on the Switch
Installing the Oracle ILOM Firmware
Acquire the Oracle ILOM Firmware Version 1.1.3
Install the Oracle ILOM Firmware Version 1.1.3
Upgrading the Switch Firmware Through Oracle ILOM (CLI)
Upgrade the Switch Firmware (Web)
Display Switch Status LED States (IPMI)
Remove the Switch From the Rack
Displays chassis FRU information.
showfruinfo
This hardware command displays the contents of the chassis FRU ID registers.
The showfruinfo command is available from the /SYS/Switch_Diag and /SYS/Fabric_Mgmt Linux shell targets of the Oracle ILOM CLI interface.
This example shows how to display the chassis FRU ID registers with the showfruinfo command.
# showfruinfo UNIX_Timestamp32 : Tue Mar 23 17:02:15 2010 Sun_Fru_Description : ASSY,NM2-36P Vendor_ID_Code : 11 E1 Vendor_ID_Code_Source : 01 Vendor_Name_And_Site_Location : 4577 CELESTICA CORP. SAN JOSE CA US Sun_Part_Number : 5413495 Sun_Serial_Number : 0110SJC-1010NG0045 Serial_Number_Format : 4V3F1-2Y2W2X4S Initial_HW_Dash_Level : 01 Initial_HW_Rev_Level : 50 Sun_Fru_Shortname : NM2, 36 ports Sun_Hazard_Class_Code : YL Sun_SpecPartNo : 885-1507-01 #
