Network Connection Requirements for SPARC SuperCluster T4-4
The following connections are required for a SPARC SuperCluster T4-4
installation:
Table 1 New Network Connections Required for Installation
Management network
1 for Ethernet switch
Connect to the existing management network
Client access network
Typically 1–2 per SPARC T4‐4 server:
Connect to the client access network. (You will not have
redundancy through IPMP if there is only one connection per
SPARC T4-4.)
