list_asset
This command should list ASR assets in your SPARC SuperCluster T4-4, including SPARC T4-4 servers, Exadata Storage Servers, and Sun ZFS Storage 7320 storage controllers.
A complete list of all qualified ASR assets that are awaiting approval are displayed.
If any missing information about the asset is required, the information pop-up will indicate the needed information. The ASR Activation window will appear and look like the following figure.
Required fields for ASR asset activation are:
Contact Name: You can only select a name associated with the support identifier. Click the drop-down menu to see the list of available names.
A contact must have the "Create SR" privilege for the asset's support identifier.
Street Address 1: Type the street address for the asset.
Country: Select the asset's country location from the drop-down menu.
ZIP/Postal Code: type the ZIP/postal code for the asset's location. If there is no postcode insert "-".
Distribution Email List: You can add email addresses that will receive all ASR mail notifications. Separate multiple emails addresses with a comma. For example:
asr-notifications-1@mycompany.com, asr-notifications-2@mycompany.com
ASR will send email to the Contact's email address and the Distribution Email List, if provided. This is a useful feature if your organization has a team that should be informed about Service Requests created by ASR.
# asradm send test email-address@company.com
This command sends a test alert e-mail to the e-mail address.
